#33 | |
Liked 431 Times in 224 Posts
If two identical cars go on the stop at the exact same time, the one with the lower cruise RPM should have more top end MPH. My personal guidelines are: 1. The 'stop on' time should be just high enough for the car to cut a light. 2. The cruise RPM should be set so that the car can at least clear the 60' beam while on the stop every pass in any weather conditions. There will be other things to consider in each case. Some cars may need to be WOT a little longer at the start to work the chassis properly. Some cars may come off the stop cleaner with a little higher 'stop on' RPM than absolutely necessary. I run oddball combinations in both of my cars, so I can't always use these principles but I use one of them in each car.
S/ST 51 S/C 53 |
