#11 | |
Liked 184 Times in 113 Posts
Using a Yank 4400PT lock up now.. The lock up make the car cruise at a decent rpm driving it on the street. D Last edited by Dan Fahey; 03-27-2018 at 11:32 AM. |
#12 |
Stocker Cam and Brakes!!
Does anyone have a problem using power brakes with a large duration cam? D |
#13 |
Liked 17 Times in 12 Posts
Lack of vacuum will be the problem.Canister or Hydro Boost (P/S) set up will fix it
Good luck
Marty Hanft |
#14 |
Liked 239 Times in 114 Posts
Most aftermarket controllers don't need a MAF . It might be a restriction on the inlet . If you don't use 4th gear , then why not lock up the converter in 3rd gear and get that benefit in efficiency ?
#15 |
#16 |
Liked 2,354 Times in 554 Posts
