Old 02-17-2018, 01:31 PM   #1
RJ Sledge
Liked 288 Times in 90 Posts
Default Parting out 67 Fairlane D/SA-F/SA Stocker
Putting my 1967 Fairlane back to street condition, 390/320 motor, C4 2.75 transmission, ATI convertor, REF headers 1 7/8-2 1/8 with merge collectors, Aerospace brake system front and rear (dual caliper setup on rear), Weld AlumaStars front and back with Goodyear tires, Kirkey aluminum seats with black vinyl covers, Braille 21lb battery, etc..
390 motor has T&D Sportsman setup, Kuntz did the Edelbrock heads, hollow stem valves, beehive springs etc., Redline camshaft with Trend Perf lifters etc..
C4 transmission is torrington bearing throughout, aluminum drums, deep pan, 2.75 first gear.
Third members Nodular and Aluminum 4.63-5.29, R&P sets, Moser 35 spline rifle drilled profile milled axles and rear wheels are 4 3/4 BC as are the rear rotors....
Most all is new or never run, just built it and its been in my shop.
Anything that has to do with a D/SA-F/SA 67 Fairlane Stocker is forsale from this car so if i did not list it, just ask and I probably have it.
210-three seven three-40zero4 with any questions.
Thanks for looking
RJ Sledge
RJ Sledge is offline   Reply With Quote
Old 02-17-2018, 07:14 PM   #2
ron b
Liked 4 Times in 4 Posts
Default Re: Parting out 67 Fairlane D/SA-F/SA Stocker
rj, any good shocks that also fit 68 mustang?
ron b is offline   Reply With Quote
Old 02-18-2018, 03:27 PM   #3
RJ Sledge
Ron I sent you a private message, respond by PM
RJ
Old 02-19-2018, 06:38 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Where are you located?
Rich Taylor
I/SA - 321
Old 02-20-2018, 09:50 AM   #5
6maverick9
RJ I left you a message on the New FE forum, interested in the C4 bell, the brakes, and was all so wondering if you have any extra of the standard trim for a 67 Fairlane post car
Thanks
6maverick9 is offline   Reply With Quote
Old 02-21-2018, 10:19 PM   #6
Jim Cimarolli
Liked 166 Times in 46 Posts
Talking Re: Parting out 67 Fairlane D/SA-F/SA Stocker
Hey Are Jay, would you happen to have one of those original Canadian built C4 transmissions that came in Mercury pickups?
Jim Cimarolli is offline   Reply With Quote
Old 02-22-2018, 03:57 PM   #7
Liked 10,761 Times in 2,237 Posts
Well said Jim
Old 02-25-2018, 01:35 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
No Cimo, I don't think he has any of the Mercury Truck parts, but Are Jay has a shelf full of those Shelby rubber lobed camshafts for FE Fords.... You know the kind that check right on the spec then when you rev it up they get more lift and duration.
Adger Smith (Former SS)
