Old 08-01-2017, 01:48 AM   #1
David Lee
Liked 346 Times in 126 Posts
Default Re: Street car to stocker....how much?
how about in the beginning just build it into a nice bracket car and let it evolve
Old 08-01-2017, 03:27 AM   #2
Everett Vassar
Liked 2 Times in 2 Posts
Yep that's kinda what I meant. Cal tracs 9" slicks etc. Stocker with a bracket motor
Everett Vassar is offline   Reply With Quote
Old 08-01-2017, 10:31 AM   #3
John4428
John4428's Avatar
The pure stock deal is not hard to do at all. Depending on weight if im not mistaken an lt1 fbody can run D/PS. With a very small amount of work you should be able to run under that index to at least get you out there and racing. There are very few pure stockers in our area anyway so a heads up is a pretty slim chance. You really wont need to mess with the suspension too much to make it work, and the stock 10 bolt is a lot stronger than people give it credit for.
Holler if you have any questions, i've looked at about every option you are currently looking at in the last year with mine. I haven't spent a ton of money on mine and i've qualified mid pack at each race so far being 150 pounds heavy in C/PS.
John4428 is offline   Reply With Quote
Old 08-02-2017, 12:12 AM   #4
Everett Vassar
You think the stock 10 bolt will live behind the 6 speed manual? I'm dying to dump the clutch off the starting line with 9" radials. Do you know what the index is for D/PS?
Congrats on your win in the pure stocker JLJ
Old 08-02-2017, 03:26 AM   #5
Everett Vassar
OK I think I found it D/PS 13:10 according to the car magazines back in 96,this car was in the 14:20 range. Sooo with a tune on the stock computer, some gear,radial DOT,s ...thinking about it
Old 08-02-2017, 11:13 AM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
BTW...if you are running stock exhaust manifolds you can run open Exhaust.
If you have Headers you need a full Muffler Exhaust System.
Headers do help even full exhaust system.
D
