Old 05-31-2017, 12:55 PM   #1
novassdude
Liked 136 Times in 49 Posts
Default Re: Nhra releases 2017 rule book amendments
Originally Posted by Ed Carpenter View Post
Shifting should be a function of the driver. No assisting devices whatsoever. The same for everybody. Just my .02
By the name automatic transmission it should not take any function of the driver or it would be a manual transmission.
A true automatic you just put it in drive and go.
novassdude is offline   Reply With Quote
Old 05-31-2017, 01:29 PM   #2
Liked 5,153 Times in 1,967 Posts
Let's not get too carried away here. Governors in automatics were OEM items, long before TA or ratchet shifters were around.
Old 05-31-2017, 01:47 PM   #3
Carguy49
Liked 3,026 Times in 725 Posts
Mark, since you work with automatics all the time, I have a question for you. Is there a limit as to when an automatic trans can be made to shift by itself?
Ron McDowell - Did Race
Old 05-31-2017, 02:12 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Most governors , or auto 1-2 shifts are based on output shaft rpm . Electronic shifts are based on engine speed . The difference is on good weather days a governor shift will appear to shift at a higher rpm , due to converter slip . Electronic shifts will shift at the same rpm regardless of the weather . Might be a problem trying to dial in a car if the weather changes during eliminations .
Old 05-31-2017, 04:36 PM   #5
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
My IHRA Pure Stocker has the electronic auto and after I installed the Baumann shift kit, it automatically shifts dead on @ 5,300 every pass, every gear
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-31-2017, 05:18 PM   #6
ss3011
ss3011's Avatar
Does your transmission have a governor ? When I raced Pure Stock we had to run the stock 13" converter , which was pretty tight , so there was not much slip in the converter at the shift point . Has the Pure Stock rules been changed , so it allows a loose converter ?
Old 06-01-2017, 07:13 AM   #7
ALMACK
ALMACK's Avatar
I do not believe it has a governor.
The ECU tells the internal shift solonoids when to open/close.
All I know is that the factory ECU does a much better job of hitting the shift points than I could ever do with a ratchet shifter
Also....any converter allowed in PS now.
I/PS '95 Mustang GT
Old 06-03-2017, 09:01 PM   #8
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Have to disagree/clarify this. I chase this with newer Fords and the 6 speed auto all the time. First, they don't necessarily shift based on RPM. They can, but more often than not it is based on MPH so really output shaft speed just like the old transmissions. I can't speak to the other brands as I don't know what they use. Also consider the amount of time between the shift being commanded and finally completed. Engine RPM continues to rise, then pulls down until finally achieving zero slippage once the correct elements are fully locked providing the next gear ratio. On those good weather days when the engine accelerates quicker, you'll see more peak RPM during the shift which leads to more initial RPM in the next gear. Probably better than a governor, yes, but certainly not perfect across all conditions.
K Danner STK 468
kdanner is offline   Reply With Quote
Old 05-31-2017, 04:33 PM   #9
ALMACK
ALMACK's Avatar
I bracket raced an automatic for years and tuned the shift points with the governor.
Just put it in D ....and it worked fantastic... shifted dead on every time on target.
I/PS '95 Mustang GT
Old 05-31-2017, 10:41 PM   #10
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
I have no problem with governors. If you can make them work then more power to ya. I know lots of guys that use them for 1-2 shift. My beef is E-shift in cars that never came with it and being used with transmissions that never came with it.
'65 Mustang SS/L & L/SA
