Old 05-31-2017, 05:18 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Nhra releases 2017 rule book amendments
Originally Posted by ALMACK View Post
My IHRA Pure Stocker has the electronic auto and after I installed the Baumann shift kit, it automatically shifts dead on @ 5,300 every pass, every gear
Does your transmission have a governor ? When I raced Pure Stock we had to run the stock 13" converter , which was pretty tight , so there was not much slip in the converter at the shift point . Has the Pure Stock rules been changed , so it allows a loose converter ?
Old 06-01-2017, 07:13 AM   #2
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
I do not believe it has a governor.
The ECU tells the internal shift solonoids when to open/close.
All I know is that the factory ECU does a much better job of hitting the shift points than I could ever do with a ratchet shifter
Also....any converter allowed in PS now.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
