Liked 53 Times in 16 Posts
In my 65 Impala Stocker, I am going to run a TH350 with the "short" tailshaft. First can I assume this is the most common type of TH350 used? The driveshaft I have is the one I used with a Jerico in my 68 Impala I used to have. I had this one made, a 3.5 inch. I cannot use this driveshaft because it is not long enough with the TH350 I will now be using. I need to get one made about 6" longer.
My question I guess is for anybody who has run a full size Chevy with a TH350 "short" tailshaft is there an issue with running such a long driveshaft ? This is a 396/325 car , highest RPM around 6700 Any info/input would be appreciated. Will Lamprecht 1965 Impala 396/325 I/SA ' |
Liked 535 Times in 110 Posts
I would talk to Mark Williams. They have a formula and could give you a reputable answer. Obviously, you could shorten it up by converting your trans. over to a 12" long tail housing if needed. All you need is the output and tail housing.
Jim Kaekel 3836 STK |
#3 | |
Liked 460 Times in 91 Posts
I have had no problems with a stock shaft @ 4400 lbs.
Bob Bender 144 O/SA 2010-2012 National Record Holder Last edited by Bob Bender; 04-12-2017 at 09:07 AM. |
Liked 319 Times in 68 Posts
Will,call Bruce P.914-591-7754 in the evening.He had one made for his Biscayne, short tail TH350,780 hp. Big Block. I believe Fleetpride in Danbury made it.
Lee Valentine 1661 STK |
Liked 75 Times in 7 Posts
Will, use 1350 joints and chrome moly trans yoke . Learned this expensive way .Broke trans yoke busted transmission case. Steve
