Old 04-08-2017, 08:14 AM   #1
Painter
Liked 162 Times in 45 Posts
Default Re: Package tray
I have found that one inch boiler plate works real well for covering the packsge tray and rear seat areas. A little difficult to get into position but i feel that it gives an extra margin of safety between the driver and fuel cell.
Painter is offline   Reply With Quote
Old 04-08-2017, 09:09 AM   #2
Liked 1,911 Times in 428 Posts
Originally Posted by painter View Post
i have found that one inch boiler plate works real well for covering the packsge tray and rear seat areas. A little difficult to get into position but i feel that it gives an extra margin of safety between the driver and fuel cell.
:d
Old 04-08-2017, 10:11 AM   #3
Hacksaw
Liked 312 Times in 175 Posts
Me thinks that's disguised ballast.
Old 04-08-2017, 10:21 AM   #4
MR DERBY CITY
Liked 8,172 Times in 1,536 Posts
That is exactly what I tell the racers that have me make CUSTOM 50 lb. package trays for their camaros and novas ....they then utter some nonsense about how they love to have weight up that high in their car....I then remind them that when they lock up the brakes at the finish line, turn the car sideways, this 50 lb. package tray could possibly decapitate them....Their final answer.....that's how you drive the stripe...
Old 04-08-2017, 12:11 PM   #5
Coleydog
Liked 53 Times in 38 Posts
Wow, if you stay on here long enough you're bound to learn all these tricks. I was thinkng about putting the stock tank back in to get around having to do this, but not now.I guess that's the last thing to do After I weight the car.
PS. I'm hoping its light enough to use that trick.
Old 03-28-2018, 07:25 PM   #6
David Lee
Liked 346 Times in 126 Posts
this is an older thread I started, do we have to have the package tray area upholstered or can it just be painted?
Old 03-28-2018, 07:39 PM   #7
FED 387
Liked 334 Times in 181 Posts
just remember that aluminum is about 1/3 the weight of steel --- so if you install a 1/2 inch thick steel gas tank shield between the OEM gas tank and the trunk floor you should be ok and exceed the NHRA guidelines for the thickness suggested. Make sure you have really good straps supporting that tank (lol)
Old 03-28-2018, 08:46 PM   #8
David Lee
LOL
I jave all the wholes covered with the proper thickness, can i paint it or do i have have to have some material covering it
Old 03-28-2018, 09:31 PM   #9
Liked 5,143 Times in 1,964 Posts
Originally Posted by David Lee View Post
LOL
Get some matching latex and then empty out your vacuum cleaner bag into it. If you do it right, it will look like tweed.
Old 03-29-2018, 08:29 AM   #10
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Reminds me of the story I read on CR a long time ago about a racer hiding iron Hemi heads in the back seat cushion! Art Leong, maybe?
Paul Merolla is offline   Reply With Quote
