Old 10-07-2016, 11:39 PM   #21
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Congrats Duane Dickens K/SA Record
Appears Monahan went 11.39 Marshall went 11.06 in J, can't imagine what he would go in K? Teens I suppose?
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 10-08-2016, 12:30 AM   #22
Dickens
Liked 12 Times in 8 Posts
Very impressive! Marshall may be able to run 10's in J
Dickens is offline   Reply With Quote
Old 10-08-2016, 01:52 AM   #23
HP HUNTER
Liked 373 Times in 129 Posts
When factored tracks are mentioned, I can guarantee you will pickup more than the .19 they give you at Kearney, (28.00 best the baro ever gets there) at these tracks that see a 30.0 or better baro especially in a K car. Lets say a .19 gain equates to 2 MPH, 2 MPH is approx 21 observed HP. You can be very sure going from a 28.00 to a 30.0 baro on the dyno is more than 21 HP.
Old 10-08-2016, 06:18 AM   #24
Liked 10,837 Times in 2,252 Posts
A tip of the hat to all the racers that have attempted to set records, and admiration to all that have set records. Pulling your stuff apart in front of God and everybody takes a special kind of racer.
Records are made to be broken
Old 10-08-2016, 07:54 AM   #25
james schaechter
10-4 Larry. Setting records are to be admired and rewarded. The only people that bash record breakers typically don't put their money where their mouth is! Maybe I should start a record breaker challenge for my favorite class! Congratulations to all record breakers!
James Schaechter 3163 STK
Old 10-12-2016, 09:53 AM   #26
RAY ADAM
Liked 43 Times in 4 Posts
gene monahan went 11:39 in k/sa congrats.
RAY ADAM is offline   Reply With Quote
Old 10-12-2016, 10:44 AM   #27
Tom Moock
Liked 10 Times in 6 Posts
If you compare Marty Buth record's at Kearney and Indy in real good air, his car is 3 ten's faster in real good air. .15 different in index's 11.39 in N/SA to 11.84 in O/SA corrected. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-12-2016, 11:17 AM   #28
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Congrats Duane Dickens K/SA Record
Great job,Duane! We both know that where K is concerned, there's a lot of hungry sharks in that pond. I always like seeing your Nova run!
