#11 |
yes they are legal
Jeff Essmann 5780 ss/ja WEB SITE WITH MY RACECAR |
#12 |
Liked 279 Times in 68 Posts
David, my car weighs between 3320 and 3470 depending on the class. Speed is 117-120mph. Hope this helps. Thanks Woody.
#13 | |
Liked 346 Times in 126 Posts
Mine will about that weight too, I just wanted to make sure I bout the right setup. The last thing I want is to end up without enough braking power. Did you change the MC and add any proporting vavles etc? |
#14 |
on my set up i used a mopar master cylinder its identical to a wilwood and cost1/4of the price. you will have to use a wilwood residual valve on the front and rear brake line use the 2 pound for disc brakes summitt carries them
#15 |
David I used the strange 1 1/8 bore master cylinder with no proportioning valve.
