#11 |
Liked 204 Times in 54 Posts
I recently removed the door braces on my son's Mustang. They weigh about 30 lbs together. The doors in the early fox bodies have large braces in them. The ones from about 90 on have much smaller bars.
Each bar had to be cut in three places. One cut in the middle and a cut on each end. The only tool that worked for me was a cut off tool. I used both a small straight cutter and 90 degree cutter to get it done. I was going to try a plasma cutter but it just didn't seem like a good idea. I put an 1/8" thick, 8" X 8" sheet of of aluminum between the bar and the door skin where I made the cuts in order to avoid hitting the door skin. Once you see the aluminum stop cutting. You need to remove just about everything in the door to make the cuts and get the bars out. It's a pretty big job but well worth it. The doors close so much easier and the weight can be moved to a better location. Use long sleeves and wear gloves. |
