Old 07-31-2015, 09:40 AM   #6
MadMax404
Default Re: Do grade points go with the driver or the car?
Its essentially one or the other like stated above. Driver can earn points or owner can earn points, whichever is designated at the event per the driver's tech card.
Grade points are earned via eliminator not eliminator "class". Unless this has changed in 2015 you can only use grade points on a higher eliminator not a lower eliminator.
I.E a Stock elimintor driver can earn stock points at divisionals and use them for Super Stock at a National Event however a Super Stock driver at a divisional cannot use them for Stock at a national event. This was the rule in 2013/14 as I used my Super Street grade points in Super Gas and Stock but I could not use my Stock grade points in Super Street.
Mad Max NHRA/IHRA Stock 4040
Mickey Thompson Tires;Mothers Polish; Champion Brands Oils
MadMax404 is offline   Reply With Quote
