#30 |
Liked 99 Times in 60 Posts
Comfort and convenience when in the "command center"
Out with old fashion crank up windows ! In with new Delco motor/regulator assemblies. Parts from an S - 10 Blazer are a direct bolt in. Finding door switches and wiring harness would require scouting the U Pull It's but I have no desire to spend time doing that. Instead, source two DPDT momentary switches on - off - on from local store for $9.00 each. Then build a custom harness and switch mount. Total time for wiring and switches about two hours. I would still be at the U Pull it.
Larry Woodfin 471W |
