Old 02-15-2015, 03:31 AM   #24
Andy G
Liked 8 Times in 2 Posts
Default Re: Hydraulic Rollers
When checking the NHRA engine specs for the 1987, 307/138 olds I see that the diameter for these roller lifters is .698".
Is there an advantage to the smaller diameter lifter? I would think that that the larger diameter would be more stable in the bore at higher RPM. The smaller diameter would be lighter. Is the diameter a factor in choosing the better lifter for stock eliminator?
Andy G is offline   Reply With Quote
