Old 01-13-2015, 03:14 PM   #1
J.R. Haddad
Liked 1,470 Times in 308 Posts
Question Hydraulic Rollers
Who makes the lowest "plunge" hydraulic roller, or is that the result area
to be looking at? J.R.
J.R. Haddad is online now   Reply With Quote
Old 01-14-2015, 10:22 AM   #2
Lou Jeffery
Default Re: Hydraulic Rollers
We have run several Hydraulic roller cam engines, Ford and Chevrolet using production lifters with no issues. Keep in mind they are relatively low lift Crate motor stock cams. Maybe WE are missing out on some performance but never any problems. Louis Jeffery
Lou Jeffery is offline   Reply With Quote
Old 01-14-2015, 07:08 PM   #3
J.R. Haddad
Hi Lou, thanks for the reply. I'm not having any problem with mine, it is that when I checked them, they drop 145 thousands, and to be legal
I can run one's that only drop 30 thou. Sounds like leaving a lot on the table to me. J.R.
Old 01-14-2015, 09:35 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
When they are running, they wont drop any. You are just measuring the total range that is built into the lifter plunger.
Old 01-14-2015, 11:52 PM   #5
J.R. Haddad
SS3011, interesting. I am trying to learn about hydraulic rollers as I have never run them before. It's interesting the different opinions you can get.
I have had 2 people(1 Racer, 1 Manufacturer) tell me they have back to backed cars at the track, changing oil from 5/20 to 20/50 to keep the lifters "up", and both picked up .03-.04. Keep in mind they also had to overcome the difference in the oil. True story? Who the hell knows.
I'm just trying to buy the right stuff once, instead of twice. J.R.
Old 01-15-2015, 12:16 AM   #6
Liked 5,129 Times in 1,956 Posts
JR, It isn't very hard to restrict the travel in a hyd. lifter, once you get one apart.
Just have to use good grade, consistent thickness washers. (aviation grade or similar), once you figure out what you need.
Then you won't have to worry about it.
Old 01-15-2015, 01:32 AM   #7
J.R. Haddad
Thanks Mark. That's what I was looking for! J.R.
Old 01-15-2015, 10:07 AM   #8
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Sherman's used to do roller lifters for stockers, I do not the number now.
Old 01-15-2015, 10:43 AM   #9
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Allen Sherman told me his Dad still does the hydraulic roller lifters, E-mail, shermanracing@bellsouth.net, or call (225) 473-4923, (225) 717-1460, (225) 717-1461
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 01-15-2015, 11:49 AM   #10
FINESPLINE
FINESPLINE's Avatar
You might want to check out Morel lifters. A variety of hydraulic roller lifters.
FINESPLINE is offline   Reply With Quote
