I just read this posted on the tech section, then read it again, then one more time. My definition of leaving the "staging area" is when I'm paired to race before the water box. Now they say it's before the staging lanes but the rule says before the vehicle leaves the staging area...
Stock and Super Stock Staging lane Rule Reminder This is a reminder to all Stock and Super Stock Racers that prior to reaching the head of the staging lanes all ice, towels, rags, etc must be removed per the 2014 NHRA Rulebook General Regulations, Section 20, page 5, Fuel /Air – Fuel/Air: Any method of artificially cooling or heating fuel prohibited (i.e., cool cans, Freon, wet rags, etc.), except as noted in Class Requirements. Cool cans, wet towels, etc. are permitted in Super Stock, Stock, Super Comp, Super Gas, Super Street, and E.T. classes. Wet towels, rags, ice, etc. must be removed before vehicle leaves staging area. Ambient- temperature air only; cooling or otherwise changing the conditions of the intake air is prohibited. Spraying of intake with any artificial spray or coolant prohibited. Any help would be appreciated. Thanks Tim Last edited by Tim Lisson; 08-28-2014 at 12:44 PM. Reason: wrong section, really confused obviously |
Liked 279 Times in 68 Posts
I'm glad you posted that. I've used ice bags every time I've ever had a heads up or class race.
Greg Hill 4171 STK |
Liked 100 Times in 45 Posts
Depends on what you consider the head and the tail. Sounds good to me.
Former NHRA #1945 Former IHRA #1945 T/SA |
Liked 101 Times in 52 Posts
Would have been much clearer to say either prior to entering staging lanes or before leaving staging lanes. Is anyone actually removing ice or towels in the burnout water area?
Liked 56 Times in 10 Posts
We had this question also so prior to the Allstars final in Joliet I went to all the tech guys and asked. I was told EVERYTHING had to be off prior to going INTO the staging lanes. No bags of ice, no cold towels or anything.
#6 | |
Liked 1,874 Times in 422 Posts
Never been told that. We've had ice and towels on the intake right up until it was started to go to the water.
Alan Roehrich 212A G/S |
Liked 19 Times in 5 Posts
Quite sure that they are icing in the lanes at Indy...
Racing web page |
on my past experience, since I am the ice man on the car. @ Baytown (national event) was told no ice past the stripe in the back of the staging lanes (beginning). @ No Problem (divisional) was told no ice past the stripe leaving the staging lanes - the same stripe after crossing that dial-ins cannot be changed.
Troy "City Dog" Pourciau |
It's as clear as can be to me. The 3rd sentence from the end says all artificial cooling must be removed before leaving staging area. I'd wager you could go out of the rear of staging with no consequences?
SADLY, some of the tech people have their own interpetations of these rules! |
