Old 07-21-2014, 12:57 PM   #11
Liked 5,125 Times in 1,953 Posts
Default Re: 1978 Mustang II
Originally Posted by impstocker View Post
Hello, i have a question when you said the "pads were reversed" on the rear. I just did a 9 inch rear for a friends 64 Falcon. It was a junkyard rear that I started with without brakes. I believed I assembled the brakes right using a diagram, but one side the drum is tight. Seeing this is my first Ford experience i seem to run into these problems (on third set of front spindles-right now) Could my pads be "reversed" They seem to be the same side to side> I do.t want to hijack this thread, but i could use some help.
Will Lamprecht I/SA 65 Impala inprogress.
Will , Robt. was talking about rear "shoes" not pads. And no , switching a primary shoe with a secondary won't, in itself prevent the drum from slipping on.
New drums, news shoes....you're gonna start out on the tight side. I suspect the shoes weren't centered..that's all.
