Liked 53 Times in 16 Posts
Hello, i have a question when you said the "pads were reversed" on the rear. I just did a 9 inch rear for a friends 64 Falcon. It was a junkyard rear that I started with without brakes. I believed I assembled the brakes right using a diagram, but one side the drum is tight. Seeing this is my first Ford experience i seem to run into these problems (on third set of front spindles-right now) Could my pads be "reversed" They seem to be the same side to side> I do.t want to hijack this thread, but i could use some help.
Will Lamprecht I/SA 65 Impala inprogress. |
#2 | |
Liked 5,153 Times in 1,967 Posts
New drums, news shoes....you're gonna start out on the tight side. I suspect the shoes weren't centered..that's all.
Liked 154 Times in 34 Posts
hi-I was wondering about the correct carb size for this combo-I looked on the NHRA website and it does not list venture size? tried researching the part number listed and found it is a 1.21 not a 1.08? thanks-Brian
#4 | |
Apparently there is one that can use the 1.21,, but I'm gonna stay out of that situation.
#5 | |
Liked 8 Times in 7 Posts
without losers,winning means nothing. |
so the 1978 302 mustang came with a 1.08 carb and never came with a 1.21 carb? but somehow it was approved by NHRA for stock? and....and some people knew it and didn't say anything to NHRA...meanwhile records are being set and class wallys are being won and we are all ok with this...really? someone tell me this is not so..brian
#7 | |
okay-so is the NHRA approved carb for this combo is the 1.21 or 1.08?
Liked 240 Times in 112 Posts
[/size]AH HA Rated too high.
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 07-26-2014 at 05:18 PM. |
