#11 |
Liked 346 Times in 126 Posts
#12 |
Liked 56 Times in 27 Posts
David ,
This is Stock right , No- Spraying at all , so why even bring it up !!!!! He made a bad joke , it's Over .... have a nice Day...
Dave Ribeiro 1033 STK |
#13 |
#14 |
What started out as an interesting, news worthy thread kinda took a wrong turn.
#15 |
Liked 160 Times in 51 Posts
Whatever cam you try, be careful to check piston to valve clearance, especially intake as there is more or less room depending on what piston you use. If you have a quality stocker piston w/ valve reliefs in the right place and angle, no problem most choices. If you are using factory stock or low buck cast pistons, valve clearance is way less forgiving. Let your clay be your guide!
#16 |
Liked 4,377 Times in 502 Posts
Make sure your piston is above the deck by at least .001
#17 |
Bobby,
out of curiosity, is this just to get proper quench? i'm .005 in the hole (asked for zero deck, took my budget build to a budget shop, so that's what I get I guess . . .) thanks
Alex Cummings Newb |
#18 |
It is a rule that you will not find in the rule book but one for which you can get disqualified if they tear down your engine. I know of a racer a few years back who got bounced for it and was using a bone stock bottom half. The '88 Mustang 5.0 is spec at .0135 above the deck along with a .041 gasket so you have to be at least .001 above and then you can use a thinner gasket.
#19 | |
wow. Good to know!! Dang, I might have to take this block back.
#20 |
Liked 275 Times in 76 Posts
Alex,
That spec is in the engine blueprints. It shows like Bobby pointed out 0.0135ab. Sean
