Old 02-21-2014, 07:24 PM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: best cam for L/SA 89 Mustang
Originally Posted by Dave Ribeiro View Post
David,
What's a little spray among friend's.............?
it matters what is being sprayed and where!
Old 02-21-2014, 07:41 PM   #12
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: best cam for L/SA 89 Mustang
David ,
This is Stock right , No- Spraying at all , so why even bring it up !!!!!
He made a bad joke , it's Over .... have a nice Day...
Dave Ribeiro 1033 STK
Old 02-21-2014, 07:56 PM   #13
David Lee
David ,
I was talking about someone's leg not into an engine
Old 02-21-2014, 09:43 PM   #14
7423
What started out as an interesting, news worthy thread kinda took a wrong turn.
7423 is offline   Reply With Quote
Old 02-22-2014, 09:19 AM   #15
fordteacherguy
Liked 160 Times in 51 Posts
Whatever cam you try, be careful to check piston to valve clearance, especially intake as there is more or less room depending on what piston you use. If you have a quality stocker piston w/ valve reliefs in the right place and angle, no problem most choices. If you are using factory stock or low buck cast pistons, valve clearance is way less forgiving. Let your clay be your guide!
fordteacherguy is offline   Reply With Quote
Old 02-22-2014, 09:27 AM   #16
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,377 Times in 502 Posts
Make sure your piston is above the deck by at least .001
'65 Mustang SS/L & L/SA
Old 02-22-2014, 10:02 AM   #17
alejan1975
Bobby,
out of curiosity, is this just to get proper quench? i'm .005 in the hole (asked for zero deck, took my budget build to a budget shop, so that's what I get I guess . . .)
thanks
Alex Cummings
Newb
alejan1975 is offline   Reply With Quote
Old 02-22-2014, 10:32 AM   #18
Bobby Fazio
It is a rule that you will not find in the rule book but one for which you can get disqualified if they tear down your engine. I know of a racer a few years back who got bounced for it and was using a bone stock bottom half. The '88 Mustang 5.0 is spec at .0135 above the deck along with a .041 gasket so you have to be at least .001 above and then you can use a thinner gasket.
Old 02-22-2014, 11:25 AM   #19
alejan1975
wow. Good to know!! Dang, I might have to take this block back.
Alex Cummings
Newb
Old 02-22-2014, 11:38 AM   #20
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Alex,
That spec is in the engine blueprints. It shows like Bobby pointed out 0.0135ab.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
