Thinking about getting one of these little weather machines. Anybody have any experience with these? How do they compare to the PA-2? Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 4 Times in 1 Post
I have one that I have used for a couple of years (no Bluetooth), and it works well for me. I know there are some fancy weather stations out there, but for the money these work well. I will probably update to the Bluetooth model, looks like that would be a good tool to help with data collection
That's it? Nobody else uses or has used this device? Jim
Liked 5 Times in 3 Posts
Works good, small and easy to use
We've had one for several years, it works flawlessly. The Bluetooth thing is new, might be time to upgrade
Chad Rhodes 2113 I/SA |
Liked 55 Times in 19 Posts
Just bought used one on ebay for 175. Seems to check out with mechanical barometer and psychrometer. Can't wait to put it to use
Liked 6 Times in 2 Posts
Jim,
I used one for 3 years( not using it now as upgraded) and never had an issue other than the original calibration for Baro and alt/ ( had to convert from Kilopascales ) and estimate actual altitude for my location. However once set, it remained steady. The wind meter is good in the staging lanes, and using the 'history" helps find irregularities. Just have to be conscious of the sample rate so as not to run out of storage or battery life. Mine was old enough that there was no blue tooth to worry about. used the weather log if there were time delays from run to actually getting back to trailer to record. For the money, I don't think you can get any better.
Mike Semeniuk 632 GTMA |
#8 | |
Liked 502 Times in 130 Posts
Eric
Eric Merryfield 1883 STK |
Liked 56 Times in 21 Posts
i have had mine for 5 years
i use it with the raceing system analysis density program the bluetooth is only good for 30 ft.
Vic Guilmino 1129 STK |
