#1 | |
Liked 38 Times in 17 Posts
http://www.nhra.net/tech_specs/class...s/2014FORD.xls http://www.nhra.net/tech_specs/engin...ts/FORD-14.rtf |
#2 | |
Liked 10 Times in 6 Posts
1964-1966 Chevy Chevelle HP change in the guide from 220 to 217 in SS as of 1-1-14, but not listed in the new adjustments just released? Tom
Tom Moock 5704 STK Last edited by Tom Moock; 12-19-2013 at 08:44 PM. Reason: forgot SS |
Liked 354 Times in 120 Posts
__________________ Same engine in a chevy II is 236 that's 19 hp less. So if I would race a chevelle in SS/LA a 13 lb class it could be 247 lb lighter than a chevy II with the same engine. How much ET would that be worth .Also why would you what to run SS/LA when you could run SS/MA where there is 4 tenths difference in index and only 2 tenths between L and K. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 12-21-2013 at 02:25 PM. Reason: added more |
Liked 112 Times in 31 Posts
Tom,
If you can get a '65 Chevelle down to 2990 with driver for SS/LA -- you be cheatin'. Time to break out the old 4-door again. When we last ran it, it was 3460 lbs. for SS/MA. Now, it's only 3425 lbs. for SS/NA, and 3210 for SS/MA. But heck, racing the Chevelle against your Nova II is like a Clydesdale against a throughbred. You deserve at least some of that 17 HP. \ Jerry |
