Old 09-12-2007, 06:31 PM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default VP C-11 question
C-11 sealed in the drum since last fall. O.K. for break-in? Will it pass fuel check? Or should it be discarded?
Thanks,
Joe
Joe Marcinowski 3377 STK
Joe Marcinowski is online now   Reply With Quote
Old 09-12-2007, 07:23 PM   #2
Woodro Josey
Liked 3 Times in 1 Post
Default Re: VP C-11 question
Joe, if it has never been opened and stored in a building and not in the sun, you should be fine!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 09-12-2007, 07:31 PM   #3
Bill Belden
Bill Belden's Avatar
Another tip for C-11, always put it back in the drum, including most of what is in the tank or fuel cell leaving just enough to start the motor if needed.
I've never failed fuel check including fuel left over from the year before, just make sure the drum is sealed good.
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 09-12-2007, 07:59 PM   #4
REGGIE WINKLES
Liked 39 Times in 9 Posts
Joe, I agree with Woodro and Bill. Keep the fuel sealed and out of direct sunlight
you should be fine. I only use C-11 and have never failed a fuel check.
Reggie Winkles
4102 J/Stick
REGGIE WINKLES is online now   Reply With Quote
Old 09-14-2007, 08:13 AM   #5
Cam
Cam's Avatar
Slightly off topic, but is there any power difference in C11 over C12 in a FI LT1?
thanks ,
Cam Chowen
6067 B/FI
Cam is offline   Reply With Quote
Old 09-15-2007, 08:46 AM   #6
Joe Marcinowski
Thanks to all for the responses. Cam, a friend told me 6 HP on the dyno over C-12 with a big block stocker engine.
Later, Joe
