#61 |
Liked 184 Times in 113 Posts
Hey. Kenny
Will be replacing my YankSS3800, installing a new Yank PT 4200 getting the trans rebuilt in next couple months. When do you need the converter? The hold up is our 94 Caprice SSuperwagon is at Maaco getting body work done. Soon getting 3.08's installed and prepped for Towing. However do have very good suggestion to save money on experimentation. Buy the YankPT 4400 or 4200 Stall converter right away. Add Blueprinted cam matching springs, headers, gears, tune and you should be making one second under ET's. Dan Last edited by Dan Fahey; 09-17-2013 at 04:04 PM. |
#62 | |
Liked 360 Times in 121 Posts
#63 |
[QUOTE=Dan Fahey;400438]Hey. Kenny
Will be replacing my YankSS3800, installing a new Yank PT 4200 getting the trans rebuilt in next couple months. When do you need the converter? The hold up is our 94 Caprice SSuperwagon is at Maaco getting body work done. Soon getting 3.08's installed and prepped for Towing. However do have very good suggestion to save money on experimentation. Buy the YankPT 4400 or 4200 Stall converter right away. Add Blueprinted cam matching springs, headers, gears, tune and you should be making one second under ET's. I like the sounds of this! I will need a converter soon and after some research the 3800 stall might be lower than I want/need. I'm going to try to make an IHRA "pro-am" style race at Lakeland, Fl Halloween weekend. Leaving it alone for this weekend (Div 2 Jackson, SC.) but things will start rollin on monday when we get home. THANKS!! PS Love the wagon tow vehicle. |
#64 |
Liked 66 Times in 37 Posts
Dad will have the 5.Slow at lakeland in I/PS
I had a new 2000 LS1 Z28. Bone stock it ran 13.10 Installed Yank TP4400, ET Streets and catback and ran 12.30 Good luck
72 cutlass |
#65 |
Thanks Daran!
#66 |
Hmmm...
I might be able to run at Lakeland too if I can catch the AutoTrain to Sandford, FL. Own a home in Altamonte can visit the renter. Plus can pick up the remaining MA Training at the same time too. Dan |
#67 |
Then get your butt down here! Its my favorite time of year here. Perfect racin weather! 2x chances to race PLUS if my feeble memory serves me there will be a S/SS combo race sat night. Ill look up the flyer.
#68 |
#69 |
Liked 51 Times in 25 Posts
If you have a 93 car it is not shifted by computer. Also your PCM is chip tuned not flash tuned. Just mt 2 cents
#70 |
Liked 181 Times in 56 Posts
Do the older cars have an Intake Air Temp sensor? I know on my GTO it would pull timing when temps went up. Only problem was it was so close to the radiator it was reading water temps in the stock location. It would slow down a ton.
