Guest
Posts: n/a
That's good that you know a reputable tuner. That can make all the difference in getting a car to run the index as well as having a reliable, consistent Stocker.
Speaking of consistent ... I've never shifted any computer-controlled car that I've raced. Turn the traction control off, put it in drive, and go. My thinking is that I'll never be quicker than any computer and definitely I won't be more consistent. Even if I picked up a hundreth or two I want the consistency. When we work hard to regulate the water temperature and ice the intake if traction stays our car is deadly consistent on the ETs by not shifting it. |
Liked 184 Times in 113 Posts
Hey. Kenny
Will be replacing my YankSS3800, installing a new Yank PT 4200 getting the trans rebuilt in next couple months. When do you need the converter? The hold up is our 94 Caprice SSuperwagon is at Maaco getting body work done. Soon getting 3.08's installed and prepped for Towing. However do have very good suggestion to save money on experimentation. Buy the YankPT 4400 or 4200 Stall converter right away. Add Blueprinted cam matching springs, headers, gears, tune and you should be making one second under ET's. Dan Last edited by Dan Fahey; 09-17-2013 at 04:04 PM. |
Liked 357 Times in 119 Posts
[QUOTE=Dan Fahey;400438]Hey. Kenny
Will be replacing my YankSS3800, installing a new Yank PT 4200 getting the trans rebuilt in next couple months. When do you need the converter? The hold up is our 94 Caprice SSuperwagon is at Maaco getting body work done. Soon getting 3.08's installed and prepped for Towing. However do have very good suggestion to save money on experimentation. Buy the YankPT 4400 or 4200 Stall converter right away. Add Blueprinted cam matching springs, headers, gears, tune and you should be making one second under ET's. I like the sounds of this! I will need a converter soon and after some research the 3800 stall might be lower than I want/need. I'm going to try to make an IHRA "pro-am" style race at Lakeland, Fl Halloween weekend. Leaving it alone for this weekend (Div 2 Jackson, SC.) but things will start rollin on monday when we get home. THANKS!! PS Love the wagon tow vehicle. |
Liked 66 Times in 37 Posts
Dad will have the 5.Slow at lakeland in I/PS
I had a new 2000 LS1 Z28. Bone stock it ran 13.10 Installed Yank TP4400, ET Streets and catback and ran 12.30 Good luck
72 cutlass |
Thanks Daran!
Hmmm...
I might be able to run at Lakeland too if I can catch the AutoTrain to Sandford, FL. Own a home in Altamonte can visit the renter. Plus can pick up the remaining MA Training at the same time too. Dan |
Then get your butt down here! Its my favorite time of year here. Perfect racin weather! 2x chances to race PLUS if my feeble memory serves me there will be a S/SS combo race sat night. Ill look up the flyer.
#8 | |
