Old 08-18-2013, 09:24 PM   #1
Dan Wilson
Default Re: DP rear axle assembly
The 426 is a upgrade of the 2009-2010 to a 2011 is what I was told , but now I am confused as is others. It is entered as a 2009 - 426. We started it up today and everything seems good except the windows stoped working . I guess they are not 426 compatible. Now we have to get them working. Will they not work with 16 volt? I converted it from 12v to 16v and they stopped working.
The 426 sounds real good.
Dan
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 08-18-2013, 09:44 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Your 426 is an 11.
Jeff Teuton 4022 STK
Old 08-19-2013, 12:08 AM   #3
GUMP
Liked 2,354 Times in 554 Posts
Originally Posted by Jeff Teuton View Post
Your 426 is an 11.
Not according to the NHRA web site! Right now, it's confused.
GUMP is online now   Reply With Quote
Old 08-19-2013, 03:52 AM   #4
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
The hood issue made them change - the combination could not be used in an 11 with a flat hood
09 + 10 hood works
IMHO - Good after thought
Ron
Old 08-19-2013, 07:06 AM   #5
Jeff Teuton
If you got a 426 Gen III from Arrow, either complete or unassembled, you will be rebadged as an 11. Originally it was to be a 13, but the final version was rebadged as a 11. The 426 has the new motor, scooped hood, and available 9 inch rear. All was to make a competitive shoot out car. The specs are almost identical to the 427 Copo motor. Now you have it.
Old 08-19-2013, 07:58 AM   #6
Billy Nees
Liked 7,724 Times in 1,738 Posts
and to think that I was told by an NHRA Tech Official just this weekend that MY car is "destroying the integrity" of Stock Eliminator! Who'da thought!
Billy Nees 1188 STK, SS
Old 08-19-2013, 08:25 AM   #7
Jeff Teuton
No, you need a blown SCJ or DP to 'destroy the integrity'. COPO's are ok cause they are Bow Ties. But then again I played this record at 78 RPM and listened about the downfall with the 62 up Max Wedge, the 64 up 426 Elephant, and all the other muscle cars. Seems like most got over it. Some will never get over it. Most of them got Chevys. But you gotta watch it, the Indians are starting to outnumber the Coyboys. Is that politically correct? I guess you could have a CJ without a blower and still 'destroy the integrity'.
Old 08-19-2013, 01:50 PM   #8
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
I thought your car was what stock eliminator was supposed to be. Thirty five years ago at Indy if you could imagine it someone had one in stock.
Kenny Miracle
P/SA 310
kwm is offline   Reply With Quote
Old 08-19-2013, 03:49 AM   #9
Andys dad
Andys dad's Avatar
Dan
Saw this problem in a build at Phil Mandella's I was involved with
It was somewhat related to the 12 to 16 conversion and manifested itself in mysterious ways - pretty sure the controller is "bunged"
Check with them (Phil or Tony) 909-941-7800 to obtain one which works
Old 08-19-2013, 07:52 AM   #10
denbreeden
denbreeden's Avatar
Liked 61 Times in 26 Posts
Dan
My DP windows work fine on 16V. I did get rid of the factory "smart" switch and put new switches in.
Dennis Breeden
denbreeden is offline   Reply With Quote
