Wondering what most guys are using for a rear coil spring in a fox body mustang stocker with a 30x9 radial?
Liked 1,599 Times in 583 Posts
Moroso or Laurel Mountain.
My 85 is a carbed stick car, with bias ply slicks, but I am just using factory V8 GT rear springs, with Air Lift bags inside.I tried the Morosos, but they seemed too weak, at least with the stick. .
Liked 79 Times in 11 Posts
I used the ones from steeda. worked very well.
bob beals 7244 |
Liked 370 Times in 101 Posts
I had the moroso rear springs, car was way too low, 95 gt moog springs might bewhat you want...I think
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
I have eibach drag launch with an air bag in the right rear. They work well but will only fit a 28 in tire
I ran stock, uncut GT rear springs in mine.
Shawn Allsup K/S 718 |
Liked 19 Times in 12 Posts
Lotsa people using stock v8 rear springs with an air bag. FOMOCO brand not aftermarket replacements. Cut one coil out to set the ride height if you want it a little lower and you are all set.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
Liked 275 Times in 76 Posts
Good shocks is the key, the factory GT springs work. AFCO double adj. No air bags.
Sean
Liked 57 Times in 33 Posts
I use the 1988 GT/Hatch progressive spring. Generally get about 4 years out of them before they get weak thats running it at 3400 lbs, and will knock the rear bumper off if it didnt have wheelie bars.
Duane Eiskant 1354 Stock/Super Stock |
