Old 06-27-2013, 12:27 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Repairing SB Chev Heads
I once had a set of small block heads brought to me for repair that had old BRC rocker shafts. Stuff was all worn out and a mess. Needed new valves as well. I convinced the racer a simple set of stud mounted rockers would be fine.
I soon discovered the stud holes had been drilled and tapped by hand as they were all crooked and if you sighted down the side it was rediculously bad.
I was able drill and tap the holes in my seat and guide machine and helicoiled every hole......They were not perfect as it was impossible to get a perfectly straight hole after what was done previously....
It all worked out well and the guy got many runs out of those heads....
Seat and guide machine or a Bridgeport is a must....if there is enough stud boss left to do anything with. I would not consider welding them as I just don't feel that is a good option
Rich Biebel
S/C 1479
Stock 147R
