Old 12-25-2012, 10:43 AM   #9
west coast
Liked 223 Times in 73 Posts
Default Re: Foxbody Stocker/Bracket Racer
You may want to pick what class you are going to run first if you are in a lower class where you dont need a rollbar that will save you alot of money and will be kinder on your suspenision parts. I think M is the break for that. Cobra route if you want to go faster higher class low 11s you will need a good stick, clutch and a 9in rear end rear suspenision renforcing. You are going to need a tranny, I take it yours has a AOD in it you will need a C4. Just some thoughts I went through when I built mine. I have a notch back and run K/SA in the high 11s.
west coast is offline   Reply With Quote
