Old 11-09-2012, 11:43 AM   #2
Run to Rund
Liked 56 Times in 29 Posts
Default Re: GM steel dually wheels---center bore question
Unless your truck is unusual, the wheels are lug-centric not hub-centric so the center hole only needs to be large enough to clear the hub. Make sure the coined lug holes match in size and depth, and the offsets are the same compared to your original wheels. Of course, wheel widths and diameters must match too.
