Old 09-05-2012, 05:06 AM   #35
Darrin Christen
Darrin Christen's Avatar
Default Re: Onan info
Originally Posted by Rich Biebel View Post
A 1999 model is probably the old design. Flathead engine. Does it have a black sheet metal cover? Big square type box? They made a 7000 Marquis back then. The best unit they ever made......Electronic governor, quiet 1800 rpm.....
If it is the old design they did not have the self diagnosing feature of the newer design units.....
Onan parts prices are pretty high and they are owned by Cummins....
I have seen a lot of bad fuel pumps on many different models. I don't doubt the fuel is killing some of them....
Yes Rich, thats the one I have, exactly as you described. I just installed a new fuel pump and a water fuel separator filter. Is there any legit reason to buy the $260 onan pump? There was a decal on the original onan pump that said you must replace with onan pump only. No explanation of why. I thought that maybe it was a flashproofing thing kind of like starters and altenators in the marine industry.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
