Originally Posted by Darrin Christen
Where do you guys read these codes? I have a 7000 marquis, I think its a 1999 year model. I have had to replace the fuel pump several times in the last few years. After the original onan pump quit I replaced it with a $50 low pressure pump from the Advanced Auto part because we were at a race when it gave up. The $50 pumps look just like the onan pump, but they don't seem to last very long. Is the Onan pump really worth the $260 they cost?
It's the government-mandated ethenol that kills the pumps. I doubt an Onan pump would do any better.
To get the code, press the stop/prime button 3x within 5 seconds. It'll then blink a single digit. Press it one more time, and it'll blink a two-digit code.
A fuel pump problem will generate a generic 36 - which stands for fuel delivery problem. Could be a pump issue, low fuel level, leaking fuel line, gummed carb, or anything else that causes the genny to starve of fuel.
It's probably one of the more common codes.
