Old 03-24-2012, 11:50 AM   #1
Jeff Kempton
Jeff Kempton's Avatar
Liked 69 Times in 33 Posts
Default Re: Need help putting gas in your car
Grounding everything may seem like overkill, but I've got a good friend in the hospital right now with 2nd and 3rd degree burns over 18% of his body due to static electricity. He was under a hot rod in his shop preparing to remove the gas tank, and as a precaution the garage heat was off and there were no incandescent trouble lights or electric tools in use. The plastic creeper he was using must have built up a charge and when he reached for the last bolt a spark jumped from the wrench to the bolt and caused an explosion. He got out alive which is what's important, but he lost the garage and two collector cars.
Static electricity is bad news.
Jeff Kempton is offline   Reply With Quote
