Liked 8 Times in 1 Post
I have first hand experience with racing accidents and I can tell you that anything that we can do to possibly prevent them is a good thing. As most of you know, we own a speed shop and everytime that someone comes in to buy there "NEW" seat belts, I hear the same old line "There is nothing wrong with my belts, NHRA is probably getting a kick back." As they complain while they spend their $70 for seat belts they normally follow that telling me about the thousands of dollars that they spent on their car so that they can pick up a tenth of a second. Something else that we all need to understand, something like the diaper rule, effects more than yourself. If you want to run old belts or no belts, if you hate yourself that much than so be it, but running a diaper prevents you from running in front of the person in the other lane and affecting their life. I have learned something over the last 10 years of my life. I love racing, I love it so much that even after the thousands of runs that I have made I still shake after a round of eliminations, but I love my life more. I love my wife, my son, my family, and my friends a whole lot more. We spend a lot of money racing and to be honest the safety aspect is probably one of the cheapest things that we spend money on. So we spend $70 every 2 years for belts. Maybe $500 for a diaper if you need a custom diaper. Pants, jackets, gloves, neck collar. That is it. So lets estimate on the high side you spend $1000 for safety equipment. I would have to think that most people would probably say that to go to a points race or national event for the weekend would probably cost them the same. So tell me is your life worth that weekend? It isn't for me.
Brian Van Poppel 1682 SS |
Tell me more about these diapers. Sometimes cars unload or break while in the air and come down hard, sometimes touching the pan. If the diaper is torn is it required to be replaced in order to be acceptable? I would think that it would be.
What happens when an engine lets go and starts a fire? Does the diaper put out the 4-5 qts. of oil that it retains? Will the diaper stop all parts from exiting the diaper? What I mean is it bullet proof? Will the extra time spent changing the oil and looking for leaks cause more problems than it solves? Some aren't much on doing regular maintenence is what I'm refering to. An oil soaked diaper might be flamable? What about the rear area of the block? I've seen cranks let go and take the flywheel and part of the converter with them. I agree with some that have said. I am more worried about the car in the other lane than I am my car. Just look at some of the wheel alignment junk from pictures of cars in the air. |
Liked 2 Times in 2 Posts
First, let me say I am not one to oppose safety, but if safety is the issue, then why is it not a mandatory rule for all NHRA, IHRA, etc. and why only 9.90 and quicker.
My understanding is that the diaper does not have to be SFI approved, can be homemade, just so you have somthing to catch the oil and does not have to be fire proof. What if I have a small leak (that I am not aware of), have a diaper on and since the diapers are not fireproof, the leak could soak the diaper and cause a fire due to hot headers, etc. Having a full bodied SS car makes it even more difficult to put on a diaper than say with a dragster due to header placement, tie rod running thru the oil pan among other things. Not being required to have a diaper to race SS but being told I cannot test at my local track because I do not have one does not sit well with me. Danny Henderson SS/GA 1795 |
In comp we have a choice between a diaper and a belly pan-we use belly pans on our cars since they are so much easier-I don't know if you could build a belly pan to fit the frames of a stocker or super stocker, but if you could, see if the track would accept them as an alternative to a diaper.
Since Hagerstown MD (Mason-Dixon Dragway) is the only NHRA Division 1 track we currently race at with our series, I sent an e-mail to Elmer (track owner) about the diaper issue. That NHRA does not yet require diapers on most Sportsman (S/SS and .90 cars), and as such, would we (S/SS) get a pass for the Lee Sherman S/SS Race in November? My e-mail first, and Elmer's replies:
"Hi Elmer. I had a question, that was brought up on a racing messageboard for Stock/Super Stock racing. It was stated that NHRA DIvision 1 is requiring an engine diaper/containment device on all 9.99 and quicker bracket cars. NHRA has, however, not mandated them for NHRA Sportsman racers at Division 1 Nat'l Opens, LODRS Divisional Events or National Events. So, would the S/SS cars competing at the Lee Sherman race in November be required to have a diaper to compete there? Diapers run up to $500, and I don't know how many of the 12 or so 9 second racers we would have in November,would want to pay that much to only need it once or twice a year. Thanks." Elmer's two replies: "Under current rules if operating as a stock or super stock event , bracket rules would not apply" and a few minutes later: "Also keep in mind that there is no certification or spec on what is a engine diaper it could be a metal tray with a pamper in it. I think you will find this to be true. The rule was put I place more for track oil downs than for other reasons in my opinion. However any thing that keeps oil off the track and from under the tires of a race car can't be a bad thing." So, for the 10-12 Class cars that run in the 9's that we would get, it looks like you will be OK for the two S/SS races we'll have in November. Hope this helps...I know several people here (Larry, Larry, Dan and Jeff) participated at H-town last November. So it looks like you will be OK for this year. Thought it appears for a normal weekly test and tune, you will need an oil-containment device.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
Liked 2 Times in 1 Post
I think I have a little more than $169.00 invested. I had to make some rather extensive mods for the diaper to perform properly, but I am glad I did it. Athey race cars did it, actually, I don't have the ability or know how to do any of this. Custom billet oil filter remote, etc.
Rapare-Racing.com Last edited by Robert Pare Racing; 03-26-2012 at 05:05 PM. Reason: I love big boobs..perfect orbs of goodness. |
#7 | |
Unfortunately those with the least amount of common sense are completely unaware of their situation.... ![]() |
Liked 64 Times in 25 Posts
I understand the issues w/the S/SS cars fitting them in tight quarters and not an easy on and off. But I cant say enough about the benefit of having one . Unfortunately I've tested them both in my S/G car and my TS car over the past 2 seasons. Both incidents happened on top end around 1000'. Both engine failures were huge, rods thru the pan, and in the TS car I broke the block. The diapers both held 95% of the oil (very minimal cleanup for the crews) and all the pieces of block and rods were in them. Both times I was able to stop the car safely, and park it out of the groove. These $200 items saved my cars and possibly my life.
Just my .02
Carl Juliano TS 1275 John Juliano SG 151 Carl Sr. |
#9 | |
"CARS & DRAGSTERS 7.50-9.99 Oil Retention device must be employed Can be self made or purchased online (no SFI rating at this time)" Danny Henderson SS/GA 1795 |
Liked 3 Times in 1 Post
I put one on my super stocker last year because I like my self. thanks DRE
