Old 03-27-2012, 04:46 PM   #1
prixmoracing
Default Re: Diaper required at Division 1 Tracks?
Originally Posted by hotrods1795 View Post
My understanding is that the diaper does not have to be SFI approved, can be homemade, just so you have somthing to catch the oil and does not have to be fire proof. What if I have a small leak (that I am not aware of), have a diaper on and since the diapers are not fireproof, the leak could soak the diaper and cause a fire due to hot headers, etc.
Danny Henderson
SS/GA 1795
You are right about it not having to be SFI approved for most classes (classes requiring SFI diapers are spelled out in the rule book under class requirements) but it does have to be NHRA approved, (list can be found on nhraracer.com )So your homemade diaper idea will not fly.
Unfortunately those with the least amount of common sense are completely unaware of their situation....
prixmoracing is offline   Reply With Quote
Old 03-27-2012, 08:23 PM   #2
Carl Juliano
Carl Juliano's Avatar
Liked 64 Times in 25 Posts
I understand the issues w/the S/SS cars fitting them in tight quarters and not an easy on and off. But I cant say enough about the benefit of having one . Unfortunately I've tested them both in my S/G car and my TS car over the past 2 seasons. Both incidents happened on top end around 1000'. Both engine failures were huge, rods thru the pan, and in the TS car I broke the block. The diapers both held 95% of the oil (very minimal cleanup for the crews) and all the pieces of block and rods were in them. Both times I was able to stop the car safely, and park it out of the groove. These $200 items saved my cars and possibly my life.
Just my .02
Carl Juliano TS 1275
John Juliano SG 151
Carl Sr.
Carl Juliano is offline   Reply With Quote
Old 03-27-2012, 09:34 PM   #3
hotrods1795
Liked 2 Times in 2 Posts
To reply to your quote about not allowing self-made diapers, below is the exact wording from a local track regarding what is required.
"CARS & DRAGSTERS
7.50-9.99 Oil Retention device must be employed Can be self made or purchased online (no SFI rating at this time)"
Danny Henderson
SS/GA 1795
hotrods1795 is offline   Reply With Quote
Old 03-27-2012, 09:41 PM   #4
600ci
Liked 3 Times in 1 Post
I put one on my super stocker last year because I like my self. thanks DRE
600ci is offline   Reply With Quote
