Old 03-23-2012, 09:29 PM   #7
George Mirza
Default Re: Diaper required at Division 1 Tracks?
This is a very 'gray" area when it comes to what safety rules class cars have to use. We have dealt with this a few times with the ASRA races. Usually the car has to fit the rules for the class it's built to race in, not the type of race that it is racing in.
Bottom line is it's up to the track. They may let you test, or run specialty races, like Stk/SS combo's, but if your going to run every week for points you'll need all the safety equiptment required for the bracket your running.
Remember, it's your ***** in the seat, as racers we try to ignor the thoughts about the consequenses of our sport. Things break, accidents happen, it's up to YOU to make sure your car is as safe as possible, and sometimes it's still not enough!
Larry, in no way is this last paragraph directed at you, I understand the situation that many stock and SS races are facing with the diaper rule. Good rule, but can be very difficult and expensive to fit a diaper correctly on most class cars.
George Mirza
ASRA B.O.D.
George Mirza is offline   Reply With Quote
