Old 01-24-2012, 01:54 PM   #51
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Team Mopar Records Unofficial Fastest Pass in Pro Stock
Todays ProStockers are unrecognizable without the name being printed on the car.
Nice to see the latest development of the original concept.
Top Stock tried to revitalize the original concept but have seen little of that in a while.
Think the key issue that killed it was trying to balance the HP values of too many engines.
IMHO Top Stock Eliminator cars should be a seperate class from Stock.
Set the weight limit to 8.00#/cuin.
Minimum weight of 3200lbs
650 CFM Carb limit, No Hood scoops, Stock Hoods.
Any Cylinder Head, Iron Blocks, NA.
Use Engine Master rules to build a 2500-6500rpm engines.
Maximum Cam Lift .550 any Rocker
10 Inch tire, Stocker Suspensions.
Have a Frontal Surface Varience factor for big faced cars.
That way a slick Vette and Polara can compete.
AND so racers can have something to gosip about.
All other Stock Eliminator Rules in play..
Dan Fahey is online now   Reply With Quote
Old 01-25-2012, 08:59 AM   #52
K Stubbs
Liked 20 Times in 3 Posts
I believe the idea of Top Stock was to be able to use a "legal" class car and adjust the weight accordingly. This way you can run the car in the eliminator as well.
K Stubbs is offline   Reply With Quote
Old 02-09-2012, 10:27 PM   #53
Mickey Whaley
Originally Posted by Andys dad View Post
I have always wondered why they go out and waste precious - valuable - testing time by running illegal just to make themselves feel good - then have to change the whole car back to legal - not sure what they learn by running hot fuel or running light - weight distribution is a big deal - different body which would not pass the template test - a wing that is applying incorrect down force
Just does not make sense to me but you guys on here probably know it all better than I do
:-) peace
60 degrees out there good weather how fast did those guys run out west?
Mickey Whaley is offline   Reply With Quote
Old 02-09-2012, 11:03 PM   #54
Ed Wright
Ed Wright's Avatar
Mike Edwards #1 again.
Ed Wright 4156 SS/JA
Old 02-10-2012, 08:45 AM   #55
Todd Boyer
Liked 6 Times in 5 Posts
Originally Posted by Tommy Gaynor View Post
Let me guess they had some Wayne County type help!
Doesn't get much lower than that Tommy. Of course we could say they got Eckman and Orndorf kind of help also ....
Old 02-10-2012, 10:14 AM   #56
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Yep! Mike Edwards has no idea what a soft tune up is. 0.982 sixty on the first pass and 168mph to the eighth. His car was moving on both ends. Looks like everyone else was a lil soft, undergeared, or too aggressive in the first round.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 02-12-2012, 02:04 AM   #57
RULER
Liked 58 Times in 18 Posts
Exclamation Re: Team Mopar Records Unofficial Fastest Pass in Pro Stock
Well look what happened when they all had to weight and fuel check, like i said on an earlier post this happens almost every year and then somebody has to say look how fast they are,
RULER is offline   Reply With Quote
Old 02-12-2012, 09:56 AM   #58
Ed Wright
Ed Wright's Avatar
Then Jason Line knocked him down to 2nd by a hundredth.
Last night the announcer said Alan Johnson has run extremely fast in pre-season testing before then appeared to struggle to match it when the season starts.
Old 02-12-2012, 12:53 PM   #59
FED 387
Liked 332 Times in 180 Posts
another thing when they test in Florida they are 50 feet above SEA LEVEL Pomona is like 1600 feet ABOVE(claremont airport is across the street from the track)---take some time off for that- coupla hun at least--while some people can run great times and test at 1600 feet not bogus times like those 50 footers
Old 02-12-2012, 02:00 PM   #60
Toby Lang
Liked 2 Times in 1 Post
Yeah, but how about that Courtney Force!!!
