#21 |
Banned
I am not talking about the Boss 302 Pushrod @ 8.20 deck hight but the 4V four cam 5.0L that is used in the new 2011 Boss 302 Car code name of COYOTE in the 2011 NHRA engine specs it shows as as a 4 Valve finger foller Engine dual overhead cam small bore long stroke
#22 |
Liked 372 Times in 130 Posts
Well, it appears this 2012 NHRA 302 listed may neither be a Mustang GT engine nor a Boss 4v.
It is possible the engine is a "made up on paper" engine..........according to this board member on Modular Fords: (post # 5) http://www.modularfords.com/forums/s...86#post1720886 "It's not a GT or a Boss according to the specs, it's an engine that doesn't exist. Someone goofed. All appearances are that it is the 2011 GT engine other than the piston and exhaust cam specs. I suspect that was the intent, to use that crate engine, much like they did with the 4.6 3V in the CJ previously. But the specs are wrong, not the first time they have submitted incorrect specs and cars got bounced for it previously too.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#23 | |
Banned
Liked 235 Times in 110 Posts
#24 |
LOL at the "crate" nomenclature.
Terry, I would be surprised if anyone can buy that exact engine direct from Ford and delivered complete in a "crate".
#25 |
Liked 19 Times in 7 Posts
Almost everyone I know that runs Stock and Super Stock that builds or has built an engine that takes advantage of the specs that are provided for their respective engines. That means cutting the decks on the blocks close to the minimum specs, cams that are close to the maximum lift, head cc's that are near the minimum in the combustion chamber, ETC. Why would you not expect Ford, Chrysler, and GM to take advantage of the same system that makes the Engine builders build their engines to the specs that give them the advantage? It is the System that is in place through both NHRA and IHRA that makes the manufacturers do what they do. Like it or not it is no different than what all racers do to be competetive.
ss/gt 93 t-bird |
#26 |
You don't see the difference between that crap and specs from a production car?
Ed Wright 4156 SS/JA |
#27 |
Liked 70 Times in 29 Posts
[QUOTE=ALMACK;266133]Here is a pic of the new Boss 5.0 4v longblock.
Like I posted before, it's a 7500 rpm (road) racing engine put into a street legal Mustang. ![]() The tell-tale sign that it's a Boss is the oil cooler. Externally, everything else looks the same as the GT engine. my mistake. I usually think of the car as opposed to the engine when someone says Boss 302
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#28 |
Liked 38 Times in 17 Posts
I know who's garage those pictures came from.
#29 | |
Liked 1,871 Times in 422 Posts
I said two years ago that what would happen is the factories could literally have "paper engines" that they never even had to assemble as prototypes or even make anything but blocks, cranks, heads, and intakes for. With the new rule, the factories could actually let a racer go through their catalog and create an engine out of part numbers, then the factory can submit the "engine" with an arbitrary low ball power rating. This new rule means it does not cost the factories more than about $500 to create a "new engine" any time they want one. They pay a guy to fill out some tech sheets and submit them to NHRA. And all they have to do is make ONE change in the cam or piston specs, and it is a different "engine". And they don't even have to make a single part. Even if NHRA said "send us a piston", the factory could just say "we're buying them from XYZ pistons, we'll have them send you one" and have "XYZ pistons" make a dozen, and submit an "original" and their "race version" to NHRA. Pandora's box is wide open now. Who knows what will come out next.
Alan Roehrich 212A G/S |
#30 |
Yes--Thanks Kris !
