Old 06-24-2011, 08:23 PM   #11
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: Where are the lower class cars?
Here is another observation. When you consider the cost of building a full high tech car, there is little difference in the cost of building a 4-bbl V8 of any variety. What I mean is, if you are building a small block Chevy, for example, there is little difference to build a 305 smogger as it is to build a top of the line high performance version. The cost of the pistons, rods, valve train, heads, machine work, suspension, roll bar/cage, transmission, accessories, trick parts, etc. etc. is the same for the 305 that runs high elevens as it is for a ten second combination. The same for about any manufacturer. So why spend all that time and money on a mid to high eleven second car when you can go tens for the same $$? The are anomalies to those characteristics, but I would dare say that Wade Owens' 283 M/SA cost just as much as a competitive C or D car. It's not until you get away from some of the basic standard 4-bbl V8 costs that things change dramatically. Now I know that an FE Ford or a Hemi costs more than a small block Chevy, but as a rule you will have some basic core costs that are the same. That is a major reason why more faster cars are built.
Dwight,true to a point about costs.But how many 305 cores (blocks,heads,intakes,cranks,
etc) can you buy for the cost of a 396/375,427 any hp rating,for that matter a 390 AMC?
I believe for the most part lower class stockers are built by guys with not a lot to spend.My car,which I bought for $125 came only in the class guide with a 258 6 cylinder.If I wanted to build a 1969 SC/Rambler (390 4 speed only) a ragtag original car would be over $10K.
Even a clone rambler non post car commands a good buck,for a rambler.
I built my car on my small budget.I've had a moderate amount of success in the past 11 years.I've worked hard at finding a way (with a lot of help from Tom Goldman) to get the car to run the number on the window.I think we've succeded at that.Now I need to race more to get the tree down again.Any car can be successful,fast or slow,with the right driver with the right mindset.
Former NHRA #1945
Former IHRA #1945
T/SA
