Liked 138 Times in 51 Posts
Sunoco Purple also seems to be one of the more "stable" fuels. Never had a problem with it in fuel check.
I absolutely agree with that. I`ve had 10 gallons in my stock gas tank all winter and have it pass the first race out. Also curious what some of you are paying for it.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
hell the fastest pass my I/SA camaro has run was on 93 octane pump gas. Have run both C12 and sonoco supreme, don't really see a difference.
Chad Rhodes 2113 I/SA |
Liked 275 Times in 76 Posts
KCIR in Kansas City sells it for $7.50 a gallon. I have not had any problems with passing either.
Sean
Chad, I wouldn't put C12 in an engine with no more compression than that. Too much octane can sure slow you down. It burns slower. C11 works well in lower compression engines. Usually need to add 5% or so WOT fuel (top 3 rows of your fuel map.)
Ed Wright 4156 SS/JA |
Liked 7 Times in 6 Posts
purple is $9.00
blue is $10.00 at 2 local tracks in Maryland. I'm ready for E-85 but I'm afraid of my 13.6 CR and short duration cam. |
#7 | |
Not surprising. "Stale" gas usually passes. If you're "close", the problem is getting fresh gas to pass in 80 to 90 degree heat.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
We have been paying $6.58/gallon for Sunoco Standard.
Nelson Kowal Stock 345 |
