#71 |
Liked 198 Times in 79 Posts
Larry, these cars have a built in sensor that only allows them to accelerate under full power in a heads up situation. It took a lot of time and effort to accomplish this but it is proving to be well worth it.
Mike Fuller 396 STK 3961 SS Last edited by Mike Fuller; 06-03-2011 at 03:07 PM. |
#72 |
Liked 43 Times in 10 Posts
Oh, now I understand: Fernandez fouled first.
Not worst, but first. We'll never know if his foul was worse, as his opponent never even had to try. This Fernandez character simply handed over a freebie. Now it all makes perfect sense. |
#73 |
Here is the helmet cam on Micheal Iacono racing Anthony Bongiovanni. I will have more photos of Super Stock later on today.
#74 |
Liked 11 Times in 4 Posts
I see guys are icing down the blowers on the Mustangs - they will eventually figure out that can be a bad thing - If you cool the case down with hot rotors inside then the rotors will rub the housing at start up taking the rotor coating off and causing the unit to loose efficiency once it comes up to temp. Or worst case the unit will seize due to rotor OD contact. It will be an expensive learning experience.
Tim Kish 3032 SS/GS |
#75 |
no no no that ice is for the other guy in the other lane for his heads up as wip that he is about to recieve for his head ache
#76 | |
Liked 3 Times in 2 Posts
Jeff Colvert SS/G,F,GT/B 4456 |
#77 |
Friday nights are for the Pros - that way we can get together with friends and chow down along with some beverages and bench racing .Here are a few photos I took before first round this morning ..........
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#78 |
#79 |
These shots are under and around the tower for first round Super Stock. It has been another great day of racing, weather has been perfect and we are all done for the day.
Tomorrow looks to be the same as does the schedule, but we will run 3 rounds tomorrow. |
#80 |
More photos.
