Old 06-03-2011, 02:45 PM   #71
Mike Fuller
Liked 198 Times in 79 Posts
Default Re: Live from Englishtown , NJ - NHRA Supernationals
Larry, these cars have a built in sensor that only allows them to accelerate under full power in a heads up situation. It took a lot of time and effort to accomplish this but it is proving to be well worth it.
Mike Fuller 396 STK
3961 SS
Old 06-03-2011, 02:48 PM   #72
Bunkster
Liked 43 Times in 10 Posts
Originally Posted by Dennis P Chapman View Post
He had Ed F he went red.
Oh, now I understand: Fernandez fouled first.
Not worst, but first. We'll never know if his foul was worse, as his opponent never even had to try. This Fernandez character simply handed over a freebie.
Now it all makes perfect sense.
Bunkster is offline   Reply With Quote
Old 06-03-2011, 03:07 PM   #73
Here is the helmet cam on Micheal Iacono racing Anthony Bongiovanni. I will have more photos of Super Stock later on today.
Old 06-03-2011, 04:18 PM   #74
Tim Kish
Liked 11 Times in 4 Posts
I see guys are icing down the blowers on the Mustangs - they will eventually figure out that can be a bad thing - If you cool the case down with hot rotors inside then the rotors will rub the housing at start up taking the rotor coating off and causing the unit to loose efficiency once it comes up to temp. Or worst case the unit will seize due to rotor OD contact. It will be an expensive learning experience.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 06-03-2011, 05:29 PM   #75
lugnut
Cool Re: Live from Englishtown , NJ - NHRA Supernationals
no no no that ice is for the other guy in the other lane for his heads up as wip that he is about to recieve for his head ache
lugnut is offline   Reply With Quote
Old 06-03-2011, 05:54 PM   #76
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Talking Re: Live from Englishtown , NJ - NHRA Supernationals
Troy if the clutch is slipping why does the tach not move? Is it an example of acceleration curve not matching the one set in the computer, and then the computer adjusting the air intake to make it match? I always thought the clutch slipped or the tires spun with the tach always moving forward!
Hey Larry, The tach only moves foward or up if it is tire spin, when the clutch slips its like it on the conveter in a auto. just kinda sets there for a instant then catches up and goes on.
Jeff Colvert SS/G,F,GT/B 4456
Jeff Colvert is offline   Reply With Quote
Old 06-03-2011, 06:33 PM   #77
Friday nights are for the Pros - that way we can get together with friends and chow down along with some beverages and bench racing .Here are a few photos I took before first round this morning ..........
Old 06-03-2011, 06:39 PM   #78
John Kelley
Smile Re: Live from Englishtown , NJ - NHRA Supernationals
John Kelley is offline   Reply With Quote
Old 06-03-2011, 07:34 PM   #79
These shots are under and around the tower for first round Super Stock. It has been another great day of racing, weather has been perfect and we are all done for the day.
Tomorrow looks to be the same as does the schedule, but we will run 3 rounds tomorrow.
ID:	7695   Click image for larger version
ID:	7696   Click image for larger version
ID:	7698   Click image for larger version
ID:	7699   Click image for larger version
ID:	7701   Click image for larger version
ID:	7702   Click image for larger version
Old 06-03-2011, 07:42 PM   #80
More photos.
ID:	7704   Click image for larger version
ID:	7705   Click image for larger version
ID:	7707   Click image for larger version
