Old 03-31-2011, 12:06 PM   #3
Bill Baer
Default Re: What Faster?
Originally Posted by jonesracing View Post
Just wanted to know what was faster, Gas or Alky. Thanks.
Well Alky will make a more midrange torque but from what we have seen on the dyno the more expensive racing gas will make about the same peak HP.
Thr real advantage to alky (naturally aspirated) is that it's less sensitive to weather changes so Alky tends to be somewhat more consistent.
Alky is also a little cheaper than the best racing gas even when you factor into it the cost of the top oil and the fact that you will use twice as much.
But alky is little higher maintenance. and IMO usually works better with fuel injection rather than a carburetor.
