#71 |
Liked 2 Times in 2 Posts
Billy,
I must have been thinking of your "offer" while I was at Indy last year. I could be psychic.
Steve Jackson |
#72 |
This could turn into a Woodstock like experience for the Class racers. You may need a bigger kitchen.
Doug Blackley 1697 STK |
#73 |
"Don't take the purple acid!" (we're saving that for the heads and intake)
#74 | |
Liked 460 Times in 91 Posts
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#75 |
Liked 28 Times in 15 Posts
Billy, while I can't afford to go all the way to PA for your Class, I do have a 6 cyl Jeep (1.5 under IHRA index) which could be available if one of those Pasty White Hands guys has a big checkbook and doesn't qualify for admission. I could even ENHANCE him with a new Engine and Trans an make him go maybe 1.75 under (probably only 1.4 inderNHRA R/SA) Might not work for some drivers, no electric shift, etc.
Good luck with the Seminar. |
#76 |
Liked 10,820 Times in 2,249 Posts
Frank, do you have a base plate to shaker adapter for the 225 slant six in the E body ???
Thanks, Larry |
#77 |
Liked 4 Times in 4 Posts
I'm seriously starting to look at the slant six, 4 sp Valiant in my yard as a fall back position.....wonder if it will wheelstand with caltracs?
JimR B/SA 1964
Jim Rountree |
#78 | |
Liked 2,741 Times in 967 Posts
The Slant Six Challenger can be run with the T/A hood but the Cuda cannot run the AAR hood as you very well know. The Slant Six Shaker stuff is very hard to come by. Jeff Teuton might have some stuff in his shop. |
#79 | |
Liked 23 Times in 13 Posts
Frank, do you have a base plate to shaker adapter for the 225 slant six in the E body ??? Larry, In 1971 if you run the aluminum head you can run the SIXPAK and I'm pretty sure that the adapters are all the same in a B or E body.
Frank Bialas 1570 STK |
#80 |
thought this may fit in with what you are referring to:
http://www.copart.com/c2/homeSearch....SEARCH_RESULTS someones next project! Patrick
Patrick McGrath |
