Old 03-17-2011, 05:39 PM   #1
Wayne W
Wayne W's Avatar
Liked 3 Times in 1 Post
Default Re: Can you settle an argument?
Originally Posted by Burner View Post
Some more pictures, these are of the day i found it, I have yet to take any more, the tach shows max at 7k(see insert) I have read several books and seems like there are several differant thoughts on the tach, anyway still have'nt made up my mind yet, still researching it. I have a Bracket finals race this week but will check out the plates ASAP.
any input welcome, thanks again
Phillip
In 68 the early cars were just Camaros with 302 on them, then part way through the year they changed the name plate to the RPO (Regular Prodution Option) "Z28" . Early SS cars had the finned hood trim like a 67 while later cars had the square port trim like a 69 car. Now days so much has been switched around over the years that facts kinda get lost.
Wayne W is offline   Reply With Quote
Old 03-17-2011, 08:46 PM   #2
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
In reference to the SS hood fin patterns, my recollection was that the long fins were on the mouse motor cars while the "square cube pattern' indicated a Rat was under the hood. (SS350 or SS396 ,67,68,69)
Old 03-17-2011, 09:13 PM   #3
Wayne W
Wayne W's Avatar
Maybe, but .......
" For the 1968 model year, the chromed hood trim for SS396 changed from the simulated finned cooler to a set of simulated carburetor velocity stacks. The early 1968 model year SS350 continued to receive the 1967-style finned hood trim, but the SS350 trim transitioned to the velocity stack trim as the year progressed. The simulated velocity stack continued for the 1969 model year with all SS cars using this same hood trim. Related to this, the part number for the 1968-69 hood is different than 1967, with the only noticeable difference being the drains used with the velocity stack trim. "
http://www.camaros.org/exterior.shtml#SSHood
