Old 11-04-2010, 02:31 PM   #4
Dave Steltz
Dave Steltz's Avatar
Default Re: Some Head and Neck Restraint info
Pat, not sure if you have to wear a sock or skirt in a door car, but the rule basically says that if you were required to wear a neck collar, and you dont (which with a HANS you dont) then you have to wear one or the other...I was kinda focused on the open car rule...talk to Ryck Campbell he can set you straight...
Lynn, when I was building my car (roadster) I was kinda thinking the same, and I have a tin interior I added , in addition to the body, in case the body got ripped off for some reason...Carbon fiber is probably a better way but at least I have something...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
