Liked 91 Times in 2 Posts
We worked on a set of heads from one of the faster Camaros in this class. They are super stock engines with more cubic inches. 750 HP and more. And you can put as much weight in the trunk as you want. Now, you know how they go so fast. Add 400-500 lbs in your trunk and you'll hook up on 7.35 x 14" tires.
You think a Stocker or Super Stock engine is expensive, try getting a quote to build one of these. Off the charts! Jerry |
