Liked 451 Times in 77 Posts
Sounds like P&G...
Ben Holt posted on moparts: I know what happened, but I'm not at liberty to talk about it yet. I don't know if there will be an appeal or not, or if it's even an option. It was a very small, simple infraction, possibly from warm engine and cold checking equipment, but it was an infraction based on the measurements. Really a shame considering the work we put in over the weekend and the driving Jim was doing. O well.....we will be at the Dutch, hopefully in the barn again!!! |
Liked 83 Times in 32 Posts
They dont P-G those motors, and if they did and it was wrong the owner is crazy not to pull the head and verify it. I mean they take those motors out every race or so anyway.
I know but it seemed like Ben posted too soon after the final for a head to be taken off...
Trying to read between the lines! |
P-G a motor?
Jason Goldsack - 1997 Track Champion - St. Thomas Dragway 1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals |
Piston dome not rite to much .002
Hammer |
Banned
Liked 235 Times in 110 Posts
????? I always C.C.ed a Hemi S/S dome down in the hole (105.2 C.C.s for a race Hemi) as its an "above block" spec. engine or any other S/S engine dome or dish for volume. I measured STOCKER pistons dome/dish with various gages (usually a dial indicator with a bridge) as they are checked differently than S/S. Whats changed?
Liked 693 Times in 205 Posts
You are correct.
Liked 10 Times in 6 Posts
The word that spread through the pits was too much piston dome.
Banned
That would have to be C.C.ed as I stated before because it is a S/S classed engine during tear down. Its not a very easy job to do in the car but can be done quite accurately if careful. If it was a stocker Hemi being checked (not this car) then the piston would be measured with a dial indicator or similar precision tool from the deck of the block at TDC for the clyinder to be checked.
Banned
A P&G gauge is like an air pump gauge graduated usually 1 to 100 in 1/4 increments like a CC tube or more depending the range of the guage. . You screw in a fitting into the spark plug hole of one cylinder. After making the rocker arms of that cylinder inoperatable so both valves stay closed you spin the engine with the starter with the fitting connected to the P&G by a hose. The reading you get on the "pump" from a puck sliding up a glass cylinder gives you XX as a reading. Add a % of factor for the temp of that cylinder measured with a thermometer and listed on a chart supplied with the P&G gauge. Then you mutiply times the number of cylinders 4,6, or 8 to get the cubic inches. They usually measure 1 to 3 cubic inches UNDER the true size of an engine IF done correctly unless it spins to fast because of a16 volt starter systems. If the figure is OVER the claimed cubic inches then either you did something wrong or its time to pull the head and physically measure the engine. Thats about as good as I can explain it on this forum. Its eaiser to use and show someone how to do it than explain it here. A P&G is not "dead on" tool but a good indication if someone is cheating or not on the size of the engine claimed. The inspector should always make sure the fitting used is the one supplied as Ive had guys try to slip by by changing fittings with a "Bleed hole" in a fitting they have and THAT would give you a false reading. I wont mention names here but I can tell you it was usually a Pro stock racer from the good ole days....LOL and it was tried at an NMCA race years ago by a well know 409 Chev. engine builder. Ya gotta keep an eye on everyone.....LOL.
