Old 09-26-2010, 09:34 PM   #1
JSLRacing
Default Re: Hemi Super Stock Challenge @ Hebron (SPOILER)
P-G a motor?
Jason Goldsack -
1997 Track Champion - St. Thomas Dragway
1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals
JSLRacing is offline   Reply With Quote
Old 09-26-2010, 09:59 PM   #2
John Leichtamer Jr
John Leichtamer Jr's Avatar
Piston dome not rite to much .002
Hammer
John Leichtamer Jr is offline   Reply With Quote
Old 09-26-2010, 10:16 PM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Question Re: Hemi Super Stock Challenge @ Hebron (SPOILER)
Hammer
????? I always C.C.ed a Hemi S/S dome down in the hole (105.2 C.C.s for a race Hemi) as its an "above block" spec. engine or any other S/S engine dome or dish for volume. I measured STOCKER pistons dome/dish with various gages (usually a dial indicator with a bridge) as they are checked differently than S/S. Whats changed?
Old 09-26-2010, 10:58 PM   #4
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
You are correct.
Old 09-27-2010, 10:57 AM   #5
Crew Chief
Liked 10 Times in 6 Posts
The word that spread through the pits was too much piston dome.
Crew Chief is offline   Reply With Quote
Old 09-27-2010, 11:17 AM   #6
X-TECH MAN
Banned
That would have to be C.C.ed as I stated before because it is a S/S classed engine during tear down. Its not a very easy job to do in the car but can be done quite accurately if careful. If it was a stocker Hemi being checked (not this car) then the piston would be measured with a dial indicator or similar precision tool from the deck of the block at TDC for the clyinder to be checked.
Old 09-26-2010, 11:25 PM   #7
X-TECH MAN
Banned
Cool Re: Hemi Super Stock Challenge @ Hebron (SPOILER)
Originally Posted by JSLRacing View Post
P-G a motor?
A P&G gauge is like an air pump gauge graduated usually 1 to 100 in 1/4 increments like a CC tube or more depending the range of the guage. . You screw in a fitting into the spark plug hole of one cylinder. After making the rocker arms of that cylinder inoperatable so both valves stay closed you spin the engine with the starter with the fitting connected to the P&G by a hose. The reading you get on the "pump" from a puck sliding up a glass cylinder gives you XX as a reading. Add a % of factor for the temp of that cylinder measured with a thermometer and listed on a chart supplied with the P&G gauge. Then you mutiply times the number of cylinders 4,6, or 8 to get the cubic inches. They usually measure 1 to 3 cubic inches UNDER the true size of an engine IF done correctly unless it spins to fast because of a16 volt starter systems. If the figure is OVER the claimed cubic inches then either you did something wrong or its time to pull the head and physically measure the engine. Thats about as good as I can explain it on this forum. Its eaiser to use and show someone how to do it than explain it here. A P&G is not "dead on" tool but a good indication if someone is cheating or not on the size of the engine claimed. The inspector should always make sure the fitting used is the one supplied as Ive had guys try to slip by by changing fittings with a "Bleed hole" in a fitting they have and THAT would give you a false reading. I wont mention names here but I can tell you it was usually a Pro stock racer from the good ole days....LOL and it was tried at an NMCA race years ago by a well know 409 Chev. engine builder. Ya gotta keep an eye on everyone.....LOL.
