Old 09-05-2010, 09:45 PM   #11
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Extict A car...
So let me see if I have this right..............
Take run of 10.000 in E/SA....
This car goes out and runs hard enough at Sea Level National Events to get a 3.25% HP hit.....
This same car would have do this 6 times at different events (if any other DP 5.7 cars run 1.25 under at the same event it only counts as once) even after getting hit 6 times the HP rating would be 378 HP (a little more than an LS-1)
Now this car will race as a natural A/SA car and weigh 3194 lbs., which is 126 lbs less than it now weighs for E/SA.....
Let's see an ET of 10.000 and than you remove 126 lbs so you end up with an A/SA car that runs 9.90's in the summer at INDY.
However, this combo would have to be hit 6 times for that to happen.....
What a plan...
Bob
Bob Mulry 7516 STK
A & M Motorsports
